Inleiding
This guide will walk you through the replacement process for the motorized swiveling component found within your Amazon Echo Show 10 3rd Gen device. The motor is responsible for allowing your Amazon Echo device to swivel and track movement when enabled. If you are having issues with the device being unable to turn and track either automatically or manually, there may be an issue with the motor component of the device and it may need replacement.
Please ensure that the camera is turned on and rotation is enabled before deeming the component in need of replacement. Please see the Amazon Echo Show 10 3rd Gen troubleshooting page for more details.
This guide requires you to pry and remove multiple components that have been glued on.
Wat je nodig hebt
With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set it aside.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Tilt the device so the side of the base beneath the connection to the display is facing upwards and in clear view.
Use a T6 Torx screwdriver to remove the two 7 mm screws from the bracket covering the ribbon cable attached to the motor mount.
Use blunt nose tweezers to carefully remove the ribbon cable bracket and set it aside.
Use blunt nose tweezers to lift up the back of the connector to disconnect the ribbon from the socket.
Use tweezers or your fingers to gently grip the ribbon cable and pull away from the board.
Make sure the cable is only being held in place by its connection to the motor and the silver bracket on the underside of the base.
