Ga door naar hoofdinhoud
Aluratek ADMPF310F Remote Sensor Replacement
Wat je nodig hebt
  1. Aluratek ADMPF310F Remote Sensor Replacement, Screen: stap 1, afbeelding 1 van 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: stap 1, afbeelding 2 van 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: stap 1, afbeelding 3 van 3
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Remote Sensor Replacement: stap 2, afbeelding 1 van 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Remote Sensor Replacement: stap 3, afbeelding 1 van 2 Aluratek ADMPF310F Remote Sensor Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Remote Sensor Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Remote Sensor Replacement, Remote Sensor: stap 5, afbeelding 1 van 1
    • Pull out the remote sensor from its holder with your hands.
    • Unsolder the remote sensor from the motherboard.
  6. Aluratek ADMPF310F Remote Sensor Replacement: stap 6, afbeelding 1 van 1
    • Resolder the the remote sensor back to the motherboard.
    • For more on how to solder check the link here.
Conclusie
Pascal Alexis
427 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 5-1, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 174
