Ga door naar hoofdinhoud
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
Wat je nodig hebt
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: stap 2, afbeelding 1 van 1
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: stap 3, afbeelding 1 van 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: stap 3, afbeelding 2 van 2
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: stap 4, afbeelding 1 van 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: stap 5, afbeelding 1 van 2 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: stap 5, afbeelding 2 van 2
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
Conclusie
Ben Toland
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-33, Amido Winter 2015 Lid van Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 13
Altijd: 2,461
