Ga door naar hoofdinhoud
AlphaSmart Pro Keyboard Replacement
Wat je nodig hebt
    1. AlphaSmart Pro Keyboard Replacement, Separating Panels: stap 1, afbeelding 1 van 3 AlphaSmart Pro Keyboard Replacement, Separating Panels: stap 1, afbeelding 2 van 3 AlphaSmart Pro Keyboard Replacement, Separating Panels: stap 1, afbeelding 3 van 3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    2. AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: stap 2, afbeelding 1 van 3 AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: stap 2, afbeelding 2 van 3 AlphaSmart Pro Keyboard Replacement, Detaching Ribbon Cable: stap 2, afbeelding 3 van 3
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • Remove front panel from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: stap 3, afbeelding 1 van 3 AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: stap 3, afbeelding 2 van 3 AlphaSmart Pro Keyboard Replacement, Prepping Keyboard For Removal: stap 3, afbeelding 3 van 3
      • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
      • Gently lift the keyboard from the rear panel.
      • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
      Vraag FixBot
      Voeg opmerking toe
    4. AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: stap 4, afbeelding 1 van 3 AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: stap 4, afbeelding 2 van 3 AlphaSmart Pro Keyboard Replacement, Detaching keyboard Ribbon Cables: stap 4, afbeelding 3 van 3
      • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
      • Pull the ribbon cable to remove it from the connector.
      • Repeat the exact steps above for the other ribbon cable.
      • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
      Vraag FixBot
      Voeg opmerking toe
    5. AlphaSmart Pro Keyboard Replacement: stap 5, afbeelding 1 van 1
      • Remove keyboard from motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ulysses Ramirez
67 Reputatie
2 handleidingen geschreven
Clemson, Team 1-1, Benson Fall 2014 Lid van Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 39
Altijd: 1,247
