Ga door naar hoofdinhoud
AlphaSmart Pro Front Panel Replacement
Wat je nodig hebt
    1. AlphaSmart Pro Front Panel Replacement, Separating Panels: stap 1, afbeelding 1 van 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: stap 1, afbeelding 2 van 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: stap 1, afbeelding 3 van 3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: stap 2, afbeelding 1 van 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: stap 2, afbeelding 2 van 2
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • You are now able to separate the front panel from the back panel.
      Vraag FixBot
      Voeg opmerking toe
    3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: stap 3, afbeelding 1 van 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: stap 3, afbeelding 2 van 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: stap 3, afbeelding 3 van 3
      • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
      • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nathan Smith
22 Reputatie
2 handleidingen geschreven
Clemson, Team 1-1, Benson Fall 2014 Lid van Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 36
Altijd: 613
