Ga door naar hoofdinhoud
Alienware m15 R6 Memory module Replacement
Wat je nodig hebt
  1. Alienware m15 R6 Memory module Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware m15 R6 Memory module Replacement: stap 2, afbeelding 1 van 1
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware m15 R6 Memory module Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware m15 R6 Memory module Replacement, Memory module: stap 4, afbeelding 1 van 1
    • Lift the system board Mylar to access the memory module.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory modulepops up.
    • Remove the memory module from the memory-module slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Andrzej
1.732 Reputatie
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 446
