Inleiding
Before starting this guide, You should take the proper precautions to prevent damage to your machine, and to you. Unplug the computer from the external power supply, then press (and hold) the power button for 3 seconds. This will ensure that the system uses any excess power in the board, significantly lowering the chance of ESD. Make sure to also have an ESD strap ready. If you do not own one, be sure to touch the metallic surfaces inside the case, before, after, and during each step. It doesn't hurt to take precautions, but it will if you don't and end up frying your shiny new PC. An Anti-static work pad is also recommended, but not required.
Wat je nodig hebt
First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
You will insert the new card. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram card. If these do not fit, DO NOT FORCE THE CARD IN. Rotate the card and try again. Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
3 andere personen hebben deze handleiding voltooid.
