Ga door naar hoofdinhoud
Alienware M17x RAM Replacement
Wat je nodig hebt
  1. Alienware M17x RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Alienware M17x RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware M17x RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware M17x RAM Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware M17x RAM Replacement: stap 4, afbeelding 1 van 2 Alienware M17x RAM Replacement: stap 4, afbeelding 2 van 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware M17x RAM Replacement, RAM: stap 5, afbeelding 1 van 2 Alienware M17x RAM Replacement, RAM: stap 5, afbeelding 2 van 2
    • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
    Vraag FixBot
    Voeg opmerking toe
  6. Alienware M17x RAM Replacement: stap 6, afbeelding 1 van 2 Alienware M17x RAM Replacement: stap 6, afbeelding 2 van 2
    • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
    • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
    Vraag FixBot
    Voeg opmerking toe
  7. Alienware M17x RAM Replacement: stap 7, afbeelding 1 van 1
    • Remove the bottom RAM card in a similar manner.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 855
