Ga door naar hoofdinhoud
Alienware M17x Display Assembly Replacement
Wat je nodig hebt
  1. Alienware M17x Display Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 Alienware M17x Display Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware M17x Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
    • Slide cover forward then carefully lift up.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware M17x Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware M17x Display Assembly Replacement: stap 4, afbeelding 1 van 2 Alienware M17x Display Assembly Replacement: stap 4, afbeelding 2 van 2
    • Carefully use the Plastic Opening Tool to unplug the battery.
    • Lift the battery up and out to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware M17x Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 1
    • Flip the laptop back over so that the Alienware logo faces the ceiling then open the lid to view the screen.
    Vraag FixBot
    Voeg opmerking toe
  6. Alienware M17x Display Assembly Replacement: stap 6, afbeelding 1 van 3 Alienware M17x Display Assembly Replacement: stap 6, afbeelding 2 van 3 Alienware M17x Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • Use a spudger as a lever to pry the black plastic siding off of the frame starting on either of the top corners.
    • Use the spudger to remove the siding from the bottom of the frame near the hinges.
    • Carefully lift the black plastic siding up and out of the hinged area making sure not to break the fragile sides.
    Vraag FixBot
    Voeg opmerking toe
  7. Alienware M17x Display Assembly Replacement: stap 7, afbeelding 1 van 2 Alienware M17x Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the screen from the top mount.
    Vraag FixBot
    Voeg opmerking toe
  8. Alienware M17x Display Assembly Replacement: stap 8, afbeelding 1 van 1
    • Avoid directly touching the connectors with anything other than plastic tools to avoid damaging the internal components.
    Vraag FixBot
    Voeg opmerking toe
  9. Alienware M17x Display Assembly Replacement: stap 9, afbeelding 1 van 1
    • Tilt the screen forward to expose the connecting wires.
    • Disconnect said wires to then lift the display assembly out of the frame.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 34
Altijd: 1,007
