Ga door naar hoofdinhoud
Alienware M17-R1 Screen Lock Assembly Replacement
Wat je nodig hebt
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: stap 1, afbeelding 1 van 1
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware M17-R1 Screen Lock Assembly Replacement: stap 2, afbeelding 1 van 2 Alienware M17-R1 Screen Lock Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware M17-R1 Screen Lock Assembly Replacement: stap 3, afbeelding 1 van 2 Alienware M17-R1 Screen Lock Assembly Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware M17-R1 Screen Lock Assembly Replacement: stap 4, afbeelding 1 van 3 Alienware M17-R1 Screen Lock Assembly Replacement: stap 4, afbeelding 2 van 3 Alienware M17-R1 Screen Lock Assembly Replacement: stap 4, afbeelding 3 van 3
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware M17-R1 Screen Lock Assembly Replacement: stap 5, afbeelding 1 van 2 Alienware M17-R1 Screen Lock Assembly Replacement: stap 5, afbeelding 2 van 2
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
    Vraag FixBot
    Voeg opmerking toe
  6. Alienware M17-R1 Screen Lock Assembly Replacement: stap 6, afbeelding 1 van 2 Alienware M17-R1 Screen Lock Assembly Replacement: stap 6, afbeelding 2 van 2
    • If the spring is defective, slide it off the end of the assembly and replace it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
William Davis
323 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 719
