Ga door naar hoofdinhoud
Alienware M17-R1 Hard Drive Replacement
Wat je nodig hebt
  1. Alienware M17-R1 Hard Drive  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Push the slider until the battery is released from its socket.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware M17-R1 Hard Drive  Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery using your fingers.
    • It may be necessary to use a plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware M17-R1 Hard Drive  Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Place the laptop face down on a hard, flat surface to have a clear view of the bottom of the computer.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware M17-R1 Hard Drive  Replacement: stap 4, afbeelding 1 van 1
    • Once you have located the hard drive, you will then need to remove the 3 mm screw using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware M17-R1 Hard Drive  Replacement: stap 5, afbeelding 1 van 1
    • Gently slide the hard drive away from the computer using the built in ridges.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
LXA054
337 Reputatie
3 handleidingen geschreven
2Gids Commentaar
where can I get the two hdd doors
Rebecca Anne Guidroz - Antwoord Deel
Hello I guess I got lucky running across this site my 2200 dollar laptop has been a brick paper weight since Mr Gates dropped support of Vista leaving a lot of non savvy pc techs hanging no where to turn prayfully this fix it site can breath new life into my Alienwares gaming mr17 r1 hard drive once more blowing dust off ("cough") as I write this help me please .
Mike Hogan Sr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 29
Altijd: 1,089
