Inleiding
The CPU Cooler is one part of the many different components that combine to make this laptop into a fine tuned machine. Double check your part and make sure it is the CPU cooler and not the GPU cooler.
Wat je nodig hebt
First begin by placing the laptop on a hard flat surface.
Remove the nine 3 mm screws that secure the back panel using a Phillips #1 screwdriver.
