Ga door naar hoofdinhoud
Alienware M15x Memory Modules Replacement
Wat je nodig hebt
    1. Alienware M15x Memory Modules Replacement, Turn the Computer: stap 1, afbeelding 1 van 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • Turn the computer over.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware M15x Memory Modules Replacement, Sliding the Battery: stap 2, afbeelding 1 van 1
      • Slide the battery latch to the unlock position as shown.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware M15x Memory Modules Replacement, Removing the Battery Pack: stap 3, afbeelding 1 van 1
      • After the Battery Pack pops up, remove the Battery Pack.
      Vraag FixBot
      Voeg opmerking toe
    4. Alienware M15x Memory Modules Replacement, Aligning the Battery Pack Tabs: stap 4, afbeelding 1 van 1
      • Align the battery pack tabs with the slots in the battery bay.
      Vraag FixBot
      Voeg opmerking toe
    5. Alienware M15x Memory Modules Replacement, Pushing the Battery Pack: stap 5, afbeelding 1 van 1
      • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
      Vraag FixBot
      Voeg opmerking toe
    1. Alienware M15x Memory Modules Replacement, Loosen the Screws: stap 6, afbeelding 1 van 1
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Loosen the two captive screws that secure the memory-module door to the computer base.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: stap 7, afbeelding 1 van 2 Alienware M15x Memory Modules Replacement, Lifting the Memory Module Door: stap 7, afbeelding 2 van 2
      • Slide the memory-module door to release the tabs and lift the memory-module door out of the computer base.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware M15x Memory Modules Replacement, Popping up the Memory Module: stap 8, afbeelding 1 van 2 Alienware M15x Memory Modules Replacement, Popping up the Memory Module: stap 8, afbeelding 2 van 2
      • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
      • CAUTION: To prevent damage to the memory module connector(s), do not use tools to spread the memory module spring-locks.
      • Use your fingertips to carefully spread apart the spring-locks on the memory-module connector until the memory module pops up.
      Vraag FixBot
      Voeg opmerking toe
    4. Alienware M15x Memory Modules Replacement, Remove the Memory Module: stap 9, afbeelding 1 van 1
      • Remove the memory module.
      Vraag FixBot
      Voeg opmerking toe
    5. Alienware M15x Memory Modules Replacement, Align the Notch: stap 10, afbeelding 1 van 3 Alienware M15x Memory Modules Replacement, Align the Notch: stap 10, afbeelding 2 van 3 Alienware M15x Memory Modules Replacement, Align the Notch: stap 10, afbeelding 3 van 3
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Vraag FixBot
      Voeg opmerking toe
    6. Alienware M15x Memory Modules Replacement, Insert the Module: stap 11, afbeelding 1 van 2 Alienware M15x Memory Modules Replacement, Insert the Module: stap 11, afbeelding 2 van 2
      • Insert the module into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
      Vraag FixBot
      Voeg opmerking toe
    7. Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: stap 12, afbeelding 1 van 2 Alienware M15x Memory Modules Replacement, Align and Insert the Memory Module Tabs: stap 12, afbeelding 2 van 2
      • CAUTION: If the memory-module door is difficult to close, remove the memory module and reinstall it. Forcing the memory-module door to close may damage your computer.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      • Align and insert the memory-module door tabs into the slots on the computer base.
      Vraag FixBot
      Voeg opmerking toe
    8. Alienware M15x Memory Modules Replacement, Replacing and Tightening the Screws: stap 13, afbeelding 1 van 1
      • Replace and tighten the two captive screws that secure the memory-module door to the computer base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Terrence15
80.125 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
8.863 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 641
