Ga door naar hoofdinhoud
Alienware M14xR2 RAM Replacement
Wat je nodig hebt
    1. Alienware M14xR2 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware M14xR2 RAM Replacement: stap 2, afbeelding 1 van 3 Alienware M14xR2 RAM Replacement: stap 2, afbeelding 2 van 3 Alienware M14xR2 RAM Replacement: stap 2, afbeelding 3 van 3
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware M14xR2 RAM Replacement: stap 3, afbeelding 1 van 1
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
      Vraag FixBot
      Voeg opmerking toe
    4. Alienware M14xR2 RAM Replacement: stap 4, afbeelding 1 van 3 Alienware M14xR2 RAM Replacement: stap 4, afbeelding 2 van 3 Alienware M14xR2 RAM Replacement: stap 4, afbeelding 3 van 3
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Alienware M14xR2 RAM Replacement, Optical Drive: stap 5, afbeelding 1 van 3 Alienware M14xR2 RAM Replacement, Optical Drive: stap 5, afbeelding 2 van 3 Alienware M14xR2 RAM Replacement, Optical Drive: stap 5, afbeelding 3 van 3
      • Unscrew the four 6.35 mm size 1 screws.
      • Pull up on the end of the orange tab to detach it from the white connector.
      • Lift the optical drive up and out of the laptop and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Alienware M14xR2 RAM Replacement, RAM: stap 6, afbeelding 1 van 3 Alienware M14xR2 RAM Replacement, RAM: stap 6, afbeelding 2 van 3 Alienware M14xR2 RAM Replacement, RAM: stap 6, afbeelding 3 van 3
      • Unscrew the two 6.35 mm size 1 screws.
      • Lift up and remove the panel covering the RAM sticks.
      Vraag FixBot
      Voeg opmerking toe
    2. Alienware M14xR2 RAM Replacement: stap 7, afbeelding 1 van 2 Alienware M14xR2 RAM Replacement: stap 7, afbeelding 2 van 2
      • Push outward on both prongs that secure the RAM sticks in place.
      • The RAM sticks will rise upward when released from the prongs.
      Vraag FixBot
      Voeg opmerking toe
    3. Alienware M14xR2 RAM Replacement: stap 8, afbeelding 1 van 2 Alienware M14xR2 RAM Replacement: stap 8, afbeelding 2 van 2
      • Grab and pull the RAM sticks up and out of their casing and set them aside.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Eugene Park
195 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-4, Forte Fall 2013 Lid van Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Leden
45 handleidingen geschreven
3Gids Commentaar
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - Antwoord Deel
I meaned r1 model
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 2,731
