Ga door naar hoofdinhoud
Alienware M14xR2 Optical Drive Replacement
Wat je nodig hebt
  1. Alienware M14xR2 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    Vraag FixBot
    Voeg opmerking toe
  2. Alienware M14xR2 Optical Drive Replacement: stap 2, afbeelding 1 van 3 Alienware M14xR2 Optical Drive Replacement: stap 2, afbeelding 2 van 3 Alienware M14xR2 Optical Drive Replacement: stap 2, afbeelding 3 van 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    Vraag FixBot
    Voeg opmerking toe
  3. Alienware M14xR2 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    Vraag FixBot
    Voeg opmerking toe
  4. Alienware M14xR2 Optical Drive Replacement: stap 4, afbeelding 1 van 3 Alienware M14xR2 Optical Drive Replacement: stap 4, afbeelding 2 van 3 Alienware M14xR2 Optical Drive Replacement: stap 4, afbeelding 3 van 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    Vraag FixBot
    Voeg opmerking toe
  5. Alienware M14xR2 Optical Drive Replacement, Optical Drive: stap 5, afbeelding 1 van 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: stap 5, afbeelding 2 van 3 Alienware M14xR2 Optical Drive Replacement, Optical Drive: stap 5, afbeelding 3 van 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jordan Ramsey
402 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-4, Forte Fall 2013 Lid van Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 34
Altijd: 3,224
