Ga door naar hoofdinhoud
Alcatel OneTouch Evolve Battery Removal
Wat je nodig hebt
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: stap 1, afbeelding 1 van 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    Vraag FixBot
    Voeg opmerking toe
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: stap 2, afbeelding 1 van 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: stap 2, afbeelding 2 van 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: stap 2, afbeelding 3 van 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: stap 3, afbeelding 1 van 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    Vraag FixBot
    Voeg opmerking toe
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: stap 4, afbeelding 1 van 2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: stap 4, afbeelding 2 van 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    Vraag FixBot
    Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
Brendan Egan
2.491 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-5, Miles Fall 2014 Lid van UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Leden
24 handleidingen geschreven
5Gids Commentaar
Thanks 4 the info.
dennisp1964 - Antwoord Deel
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Antwoord Deel
please replay
Thank you very much!
Kath B - Antwoord Deel
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 39
Altijd: 10,574
