Ga door naar hoofdinhoud
Alcatel One Touch Pop 7 Display Assembly Replacement
Wat je nodig hebt
    1. Alcatel One Touch Pop 7 Display Assembly Replacement, Volume Button Assembly: stap 1, afbeelding 1 van 1
      • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
      Vraag FixBot
      Voeg opmerking toe
    2. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 2, afbeelding 1 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 2, afbeelding 2 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
      Vraag FixBot
      Voeg opmerking toe
    3. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 3, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 3, afbeelding 2 van 2
      • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
      Vraag FixBot
      Voeg opmerking toe
    4. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 4, afbeelding 1 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 4, afbeelding 2 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 4, afbeelding 3 van 3
      • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
      • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
      Vraag FixBot
      Voeg opmerking toe
    1. Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: stap 5, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement, Rear Camera: stap 5, afbeelding 2 van 2
      • The camera is in the top left corner of the tablet. To begin removal, use the tweezers to gently disconnect the ribbon cable attached to the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 6, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 6, afbeelding 2 van 2
      • Pull the actual camera piece from the camera slot. It may stick a bit but it shouldn't be too difficult.
      Vraag FixBot
      Voeg opmerking toe
    1. Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: stap 7, afbeelding 1 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: stap 7, afbeelding 2 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement, Motherboard: stap 7, afbeelding 3 van 3
      • We now need to remove 3 ZIF connectors, all located in the bottom right quadrant. The order they are disconnected doesn't matter.
      Vraag FixBot
      Voeg opmerking toe
    2. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 8, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 8, afbeelding 2 van 2
      • Disconnect the ribbon cable and move it out of the way of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 9, afbeelding 1 van 1
      • Using a PH00 screwdriver to remove these seven 2mm screws and place them in a safe spot where you won't lose them.
      Vraag FixBot
      Voeg opmerking toe
    4. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 10, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 10, afbeelding 2 van 2
      • With the screws removed, you can now remove the motherboard. Using tweezers or just your fingers, pick up the motherboard and place it to the side.
      Vraag FixBot
      Voeg opmerking toe
    1. Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: stap 11, afbeelding 1 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: stap 11, afbeelding 2 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement, Display Assembly: stap 11, afbeelding 3 van 3
      • Using a PH00 screwdriver, remove the 6 highlighted 2mm screws.
      • Pull the ribbon cables away from the back of the display screen. The right cable can be removed completely while the left will stay attached to the front casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 12, afbeelding 1 van 2 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 12, afbeelding 2 van 2
      • Use the plastic opening tools to pry off the plastic piece at the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 13, afbeelding 1 van 1
      • Pull away the digitizer ribbon cable using the tweezers. It will stay attached to the front casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Alcatel One Touch Pop 7 Display Assembly Replacement: stap 14, afbeelding 1 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 14, afbeelding 2 van 3 Alcatel One Touch Pop 7 Display Assembly Replacement: stap 14, afbeelding 3 van 3
      • With the screws and ribbon cables removed, the display panel can be separated from the digitizer. You can pull the display panel away from the digitizer or turn it vertically and catch the display panel as it falls out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Riley Cooper
926 Reputatie
5 handleidingen geschreven
Sam Houston State, Team 12-1, Blackburne Fall 2016 Lid van Sam Houston State, Team 12-1, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G1
3 Leden
40 handleidingen geschreven
1Gids Commentaar
Hi please I will like to ask weather you have the screen in stock...am from Ghana... kindly hit me back on jamessalia11@gmail.com
Will be glad to hear from you
james salia - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 5,395
