Ga door naar hoofdinhoud
Akai MPK25 Keys Replacement
Wat je nodig hebt
    1. Akai MPK25 Keys Replacement, Face Plate: stap 1, afbeelding 1 van 1
      • Remove all the selector knob covers by pulling them off.
      Vraag FixBot
      Voeg opmerking toe
    2. Akai MPK25 Keys Replacement: stap 2, afbeelding 1 van 1
      • Using needle nose pliers, remove the washers from the four corner selector knobs.
      Vraag FixBot
      Voeg opmerking toe
    3. Akai MPK25 Keys Replacement: stap 3, afbeelding 1 van 1
      • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Akai MPK25 Keys Replacement: stap 4, afbeelding 1 van 3 Akai MPK25 Keys Replacement: stap 4, afbeelding 2 van 3 Akai MPK25 Keys Replacement: stap 4, afbeelding 3 van 3
      • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
      • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
      Vraag FixBot
      Voeg opmerking toe
    5. Akai MPK25 Keys Replacement: stap 5, afbeelding 1 van 3 Akai MPK25 Keys Replacement: stap 5, afbeelding 2 van 3 Akai MPK25 Keys Replacement: stap 5, afbeelding 3 van 3
      • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
      • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
      Vraag FixBot
      Voeg opmerking toe
    1. Akai MPK25 Keys Replacement, Keys: stap 6, afbeelding 1 van 2 Akai MPK25 Keys Replacement, Keys: stap 6, afbeelding 2 van 2
      • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
      Vraag FixBot
      Voeg opmerking toe
    2. Akai MPK25 Keys Replacement: stap 7, afbeelding 1 van 1
      • Lift the key from the front of the keyboard towards the back in order to remove it completely.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7 andere personen hebben deze handleiding voltooid.
Will Saba
412 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-6, Maness Winter 2013 Lid van Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 60
Altijd: 12,016
