Ga door naar hoofdinhoud
AirPods Charging Case Battery Replacement
Wat je nodig hebt
Video overzicht
    1. AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: stap 1, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: stap 1, afbeelding 2 van 2
      • It is difficult to teardown the AirPods charging case because the charging case features 2 fixed points and the middle part is glued with adhesive. The charging case can easily be damaged by careless methods of dissasembly.
      Vraag FixBot
      Voeg opmerking toe
    2. AirPods Charging Case Battery Replacement, Creating a pry tool: stap 2, afbeelding 1 van 3 AirPods Charging Case Battery Replacement, Creating a pry tool: stap 2, afbeelding 2 van 3 AirPods Charging Case Battery Replacement, Creating a pry tool: stap 2, afbeelding 3 van 3
      • There is currently no special repair tool for the AirPods. Therefore, we need to make a set of disassembly tools.
      • Be careful when handling sharp and thin metal as it can easily injure your hands.
      • Make a pry piece with a 0.1mm steel plate. Firstly, cut the steel plate into the shape of a pry piece with a pair of scissors.
      • Grind the edges of the pry piece with a sheet of sandpaper.
      Vraag FixBot
      Voeg opmerking toe
    3. AirPods Charging Case Battery Replacement, Preparing the pry tool: stap 3, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Preparing the pry tool: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Bend the pry piece with a cutting nipper.
      • Use tweezers to make a shielding plate.
      Vraag FixBot
      Voeg opmerking toe
    4. AirPods Charging Case Battery Replacement, Prepare for opening the case: stap 4, afbeelding 1 van 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: stap 4, afbeelding 2 van 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: stap 4, afbeelding 3 van 3
      • To avoid damaging the charging case, wrap high-temperature tape around it.
      • Next, insert the pry piece into the seam of the two fixed points.
      • Use the pry knife to pry out a gap.
      Vraag FixBot
      Voeg opmerking toe
    5. AirPods Charging Case Battery Replacement, Start opening case: stap 5, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Start opening case: stap 5, afbeelding 2 van 2
      • Insert the shielding plate.
      • Insert the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    6. AirPods Charging Case Battery Replacement, Removing the docking tubes: stap 6, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Removing the docking tubes: stap 6, afbeelding 2 van 2
      • Wedge the special pry piece into the seam to pull out the docking tubes.
      • Please do not damage the flex cable while pulling out.
      Vraag FixBot
      Voeg opmerking toe
    7. AirPods Charging Case Battery Replacement, Optional - Opening case: stap 7, afbeelding 1 van 3 AirPods Charging Case Battery Replacement, Optional - Opening case: stap 7, afbeelding 2 van 3 AirPods Charging Case Battery Replacement, Optional - Opening case: stap 7, afbeelding 3 van 3
      • If you still cannot open the case, you can build an extractor tool with two pieces of cable gland and two screws.
      Vraag FixBot
      Voeg opmerking toe
    8. AirPods Charging Case Battery Replacement, Remove the old battery: stap 8, afbeelding 1 van 3 AirPods Charging Case Battery Replacement, Remove the old battery: stap 8, afbeelding 2 van 3 AirPods Charging Case Battery Replacement, Remove the old battery: stap 8, afbeelding 3 van 3
      • Attach the charging case to the holder and dip a small amount of alcohol on the battery.
      • Pry up the battery with the pry knife and the battery connector with tweezers.
      • Then take out the battery flex cable.
      Vraag FixBot
      Voeg opmerking toe
    9. AirPods Charging Case Battery Replacement, Test new battery: stap 9, afbeelding 1 van 3 AirPods Charging Case Battery Replacement, Test new battery: stap 9, afbeelding 2 van 3 AirPods Charging Case Battery Replacement, Test new battery: stap 9, afbeelding 3 van 3
      • Take out the battery.
      • Using a multimeter is not required to successfully replace the battery.
      • Measured by the multimeter, the battery is found to have no voltage.
      • Get a new battery that has a stable voltage of 3.6v-4.0v.
      Vraag FixBot
      Voeg opmerking toe
    10. AirPods Charging Case Battery Replacement, Put in new battery: stap 10, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Put in new battery: stap 10, afbeelding 2 van 2
      • Attach the double-sided tape to the new battery.
      • Put the new battery into the charging case and connect the battery flex cable.
      Vraag FixBot
      Voeg opmerking toe
    11. AirPods Charging Case Battery Replacement, Test charging: stap 11, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Test charging: stap 11, afbeelding 2 van 2
      • Plug in the charging cable. The case should now charge normally once more.
      • Put the earbuds in. The earbuds should charge normally too.
      Vraag FixBot
      Voeg opmerking toe
    12. AirPods Charging Case Battery Replacement, Attach new battery: stap 12, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Attach new battery: stap 12, afbeelding 2 van 2
      • Peel off the double-sided tape and attach the battery to the case.
      • Install the docking tubes.
      Vraag FixBot
      Voeg opmerking toe
    13. AirPods Charging Case Battery Replacement, Test functionality: stap 13, afbeelding 1 van 2 AirPods Charging Case Battery Replacement, Test functionality: stap 13, afbeelding 2 van 2
      • Connect the AirPods to the phone. Both the charging case and AirPods can now be charged and used normally again.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
12 andere personen hebben deze handleiding voltooid.
REWA
19.384 Reputatie
55 handleidingen geschreven
4Gids Commentaar
Opening the case is the most difficult part, did it with two cheap pealing knives. And for inserting the cable you will need tweezers and this will be fiddly. Batteries are available from aliexpress and youre case will be as new.
San der - Antwoord Deel
I feel like this guide could be a lot more descriptive and helpful, especially including tips on what to do and not do for each step, rather than assume we know exactly what you mean when you give each step in one sentence bearing half a dozen words or so. Also, there's absolutely no need to build a pair of pry tools, plastic picks work fine, and won't risk damaging either the case or the battery inside. Metal tools and lithium batteries are a no-no! Geez. With a pick wedged in the seam on each side of the case, like it shows in the picture, one final pick to the front seam can then safely pry out the holder from the case. Only the last pick will be used to pry, the other two just separate the inner case and outer case keeping the clips/catches unengaged, allowing for easy lifting/prying up and removal of the inner case.
Thousand Sunny - Antwoord Deel
Are really sure that can use it plastic picks!?
Paolo - Antwoord Deel
Great guideline. It helps me to replace the battery for my AirPods. Thank you.
Tony Lopez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 179
Afgelopen 30 dagen: 850
Altijd: 59,913
