Ga door naar hoofdinhoud
AirCard 770S SIM Card Replacement
  1. AirCard 770S SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 1
    • Hold the device with the charging port side facing up.
    Vraag FixBot
    Voeg opmerking toe
  2. AirCard 770S SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Look to the left of the charging port and peel back the SIM Card slot in order to open it.
    Vraag FixBot
    Voeg opmerking toe
  3. AirCard 770S SIM Card Replacement: stap 3, afbeelding 1 van 1
    • If there is already a SIM Card in the slot, use your finger to press in the SIM Card so that it will pop out slightly. If it does not pop out the first time, press it in again.
    • The SIM Card is not shown in picture. The red circle is where the SIM Card would be located.
    Vraag FixBot
    Voeg opmerking toe
  4. AirCard 770S SIM Card Replacement: stap 4, afbeelding 1 van 1
    • Use your fingers and carefully pull out the old SIM Card.
    • The SIM Card is not included in picture. The orange circle is where SIM Card would be located on the device.
    • When reassembling the device, make sure to press in the new SIM Card all the way so that the port can be closed and you can then power on the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Caitlin Little
437 Reputatie
3 handleidingen geschreven
Marist, Team S1-G2, Chaterdon Fall 2018 Lid van Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 2,296
