Ga door naar hoofdinhoud
Air Hog Smash Bots Radio Receiver Replacement
Wat je nodig hebt
  1. Air Hog Smash Bots Radio Receiver Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Radio Receiver Replacement: stap 2, afbeelding 1 van 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Radio Receiver Replacement: stap 3, afbeelding 1 van 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Radio Receiver Replacement, External Casing: stap 4, afbeelding 1 van 2 Air Hog Smash Bots Radio Receiver Replacement, External Casing: stap 4, afbeelding 2 van 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Radio Receiver Replacement: stap 5, afbeelding 1 van 2 Air Hog Smash Bots Radio Receiver Replacement: stap 5, afbeelding 2 van 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Radio Receiver Replacement: stap 6, afbeelding 1 van 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Radio Receiver Replacement: stap 7, afbeelding 1 van 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Radio Receiver Replacement: stap 8, afbeelding 1 van 2 Air Hog Smash Bots Radio Receiver Replacement: stap 8, afbeelding 2 van 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: stap 9, afbeelding 1 van 2 Air Hog Smash Bots Radio Receiver Replacement, Radio Receiver: stap 9, afbeelding 2 van 2
    • Use the Phillips 0 screwdriver to remove two 4.75mm screws.
  10. Air Hog Smash Bots Radio Receiver Replacement: stap 10, afbeelding 1 van 2 Air Hog Smash Bots Radio Receiver Replacement: stap 10, afbeelding 2 van 2
    • Use the soldering workstation to remove the five wires. Directions on how to solder can be found here.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brittany Frecker
542 Reputatie
4 handleidingen geschreven
IUPUI, Team 1-1, Baechle Spring 2016 Lid van IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 295
