Ga door naar hoofdinhoud
Afterglow Wireless PS3 Controller Joystick Replacement
Wat je nodig hebt
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: stap 1, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: stap 2, afbeelding 1 van 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Vraag FixBot
    Voeg opmerking toe
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: stap 4, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Joystick  Replacement: stap 4, afbeelding 2 van 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    Vraag FixBot
    Voeg opmerking toe
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: stap 5, afbeelding 1 van 3 Afterglow Wireless PS3 Controller Joystick  Replacement: stap 5, afbeelding 2 van 3 Afterglow Wireless PS3 Controller Joystick  Replacement: stap 5, afbeelding 3 van 3
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
Aj Coello
1.164 Reputatie
6 handleidingen geschreven
USF Tampa, Team S19-G5, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 151
Altijd: 5,598
