Ga door naar hoofdinhoud
Afterglow Wireless PS3 Controller Button Replacement
Wat je nodig hebt
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: stap 1, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: stap 2, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement, Button: stap 2, afbeelding 2 van 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Vraag FixBot
    Voeg opmerking toe
  3. Afterglow Wireless PS3 Controller Button Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Afterglow Wireless PS3 Controller Button Replacement: stap 4, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement: stap 4, afbeelding 2 van 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Afterglow Wireless PS3 Controller Button Replacement: stap 5, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement: stap 5, afbeelding 2 van 2
    • Pull both vibration motors straight up from their holding place.
    Vraag FixBot
    Voeg opmerking toe
  6. Afterglow Wireless PS3 Controller Button Replacement: stap 6, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
    Vraag FixBot
    Voeg opmerking toe
  7. Afterglow Wireless PS3 Controller Button Replacement: stap 7, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Button Replacement: stap 7, afbeelding 2 van 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
    Vraag FixBot
    Voeg opmerking toe
  8. Afterglow Wireless PS3 Controller Button Replacement: stap 8, afbeelding 1 van 3 Afterglow Wireless PS3 Controller Button Replacement: stap 8, afbeelding 2 van 3 Afterglow Wireless PS3 Controller Button Replacement: stap 8, afbeelding 3 van 3
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Aj Coello
1.164 Reputatie
6 handleidingen geschreven
USF Tampa, Team S19-G5, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 78
Altijd: 2,698
