Ga door naar hoofdinhoud
Afterglow Wireless PS3 Controller Battery Replacement
Wat je nodig hebt
  1. Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Vraag FixBot
  2. Afterglow Wireless PS3 Controller Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Vraag FixBot
  3. Afterglow Wireless PS3 Controller Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
    • The soldering gun will loosen the bonds of the solder allowing the wires to be detached. Use this guide for further details on how to solder.
    Vraag FixBot
Conclusie
Aj Coello
1.164 Reputatie
6 handleidingen geschreven
USF Tampa, Team S19-G5, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 86
Altijd: 4,117
