Ga door naar hoofdinhoud
Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement
Wat je nodig hebt
  1. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove clear casing: stap 1, afbeelding 1 van 2 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove clear casing: stap 1, afbeelding 2 van 2
    • Use a Phillips #0 Screwdriver to remove the seven Phillips head screws.
    • Separate two halves of clear casing by holding one side and lifting the other.
  2. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove main circuit board: stap 2, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove main circuit board: stap 2, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove main circuit board: stap 2, afbeelding 3 van 3
    • Lift motors off of controller.
    • Lift circuit board off of controller.
  3. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove secondary circuit board: stap 3, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove secondary circuit board: stap 3, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove secondary circuit board: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 Screwdriver to remove the three screws.
    • Remove triggers by lifting them off the circuit board.
    • Lift the circuit board off of the controller.
  4. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove power and mute buttons: stap 4, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove power and mute buttons: stap 4, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Remove power and mute buttons: stap 4, afbeelding 3 van 3
    • Remove the power and mute button by pulling them out. They will be loose at this point and may fall out by themselves.
  5. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Troubleshooting: stap 5, afbeelding 1 van 1
    • If you've already checked different cords for your controller then you are probably already suspecting something wrong with the USB port on your controller.
    • Using a voltmeter set to check continuity, check each pin inside the female USB connector with it's corresponding gold contact on the board.
    • On the board with the connector facing away from you, the 4 gold contacts are to the right of the connector labeled V, G, D+, and D-. With the connector still faced away from you, the pins for the connector are in order 1-5.
    • Pin 1 = V
    • Pin 2 = D-
    • Pin 3 = D+
    • Pin 4 = G
    • Pin 5 = G
    • Pins 4 and 5 are GND1 and Shield1, so they will have continuity with each other. This is normal. We just need to make sure all the gold contacts have continuity to their corresponding pin and aren't crossed with any other pin.
    • If there isn't continuity on one or more of the pins inside the connector, then check the solder on the back of the connector for breaks. If there are breaks use a small heat gun or fine tip soldering iron to melt the break(s) back together.
    • If you now have continuity from the gold contacts to the other end of a cord plugged into the female connector on the board, then reassemble following the teardown guide in reverse order. If this doesn't solve your problem, then proceed to the next step.
  6. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement: stap 7, afbeelding 1 van 1
    • If the inside of the connector is damaged, then you will have to replace it. I've had several devices of mine and my kids that have bad connections due to being bent up or down and it never connects right again.
    • Using a heat gun, heat the connector up enough to melt the solder on all the pins and horns that hold it to the board and gently pull it off the board with needle nose pliers.
    • Inspect the board for damage. If any traces on the board are scratched and exposed, you can dab some super glue on them and let it dry.
    • You can install the new connector with a soldering iron with a fine tip or a small heat gun.
    • Check continuity on your new connector as described earlier in step 5 to make sure it will work with a cord plugged in. Check continuity with a cord plugged in as described in step 6.
    • If problems persist after exhausting all known troubleshooting guides for these controllers, it may be an issue with the board itself.
    • I highly recommend a magnetic tip USB cord for these controllers, because it will simply disconnect if yanked or bent at the controller.
  7. Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Alternative method of repair: stap 8, afbeelding 1 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Alternative method of repair: stap 8, afbeelding 2 van 3 Afterglow Prismatic Wired Controller for Xbox One Micro USB connector Replacement, Alternative method of repair: stap 8, afbeelding 3 van 3
    • If you have damaged the traces to the connector like I did, then installing a new connector is not possible or extremely difficult. All is not lost. Simply cut off the connector to an old USB cord, strip the wires, and solder them onto the board as shown in the picture. Cut a slot into the black piece where the connector was and reassemble.
    • Hot glue the opening where your new cord is coming out to prevent movement of the wires and cord. I have tested the controller and it lights up and fully functional again.
Conclusie
Afterglow Prismatic Wired Controller for Xbox One Teardown
Daniel B Rapier
161 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 49
Altijd: 3,190
