Ga door naar hoofdinhoud
Acer Iconia One 7 Battery Replacement
Wat je nodig hebt
    1. Acer Iconia One 7 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Acer Iconia One 7 Battery Replacement: stap 2, afbeelding 1 van 1
      • Using a plastic opening tool, separate the back cover from the main device.
      • Open each side continuously to ensure all sides have been separated.
      Vraag FixBot
      Voeg opmerking toe
    3. Acer Iconia One 7 Battery Replacement: stap 3, afbeelding 1 van 1
      • Turn the tablet over so the battery is facing up.
      Vraag FixBot
      Voeg opmerking toe
    4. Acer Iconia One 7 Battery Replacement: stap 4, afbeelding 1 van 2 Acer Iconia One 7 Battery Replacement: stap 4, afbeelding 2 van 2
      • Carefully pull back the black tape covering the battery lead connector.
      • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. Acer Iconia One 7 Battery Replacement: stap 5, afbeelding 1 van 3 Acer Iconia One 7 Battery Replacement: stap 5, afbeelding 2 van 3 Acer Iconia One 7 Battery Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Using a plastic card or opening pick, separate the battery from the rest of the device.
      • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Ahmad Kayali
458 Reputatie
1 Handleiding geschreven
USF Tampa, Team 8-5, Eyestone Fall 2015 Lid van USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Leden
25 handleidingen geschreven
4Gids Commentaar
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Antwoord Deel
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Antwoord Deel
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Antwoord Deel
Where I can order the new battery part?
melanieloa3 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 57
Altijd: 19,157
