Ga door naar hoofdinhoud
Acer Iconia A110 On/Off Switch Replacement
Wat je nodig hebt
  1. Acer Iconia A110 On/Off Switch Replacement, Battery: stap 1, afbeelding 1 van 2 Acer Iconia A110 On/Off Switch Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 On/Off Switch Replacement: stap 2, afbeelding 1 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 2, afbeelding 2 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 2, afbeelding 3 van 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 On/Off Switch Replacement: stap 3, afbeelding 1 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 3, afbeelding 2 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 3, afbeelding 3 van 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
  4. Acer Iconia A110 On/Off Switch Replacement, Speaker: stap 4, afbeelding 1 van 2 Acer Iconia A110 On/Off Switch Replacement, Speaker: stap 4, afbeelding 2 van 2
    • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
    • Two 2.0 mm screws (with the bigger head)
    • Four 2.5 mm screws (with the smaller head)
  5. Acer Iconia A110 On/Off Switch Replacement: stap 5, afbeelding 1 van 2 Acer Iconia A110 On/Off Switch Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
    • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
    • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
  6. Acer Iconia A110 On/Off Switch Replacement: stap 6, afbeelding 1 van 2 Acer Iconia A110 On/Off Switch Replacement: stap 6, afbeelding 2 van 2
    • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
    • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
  7. Acer Iconia A110 On/Off Switch Replacement, Motherboard: stap 7, afbeelding 1 van 3 Acer Iconia A110 On/Off Switch Replacement, Motherboard: stap 7, afbeelding 2 van 3 Acer Iconia A110 On/Off Switch Replacement, Motherboard: stap 7, afbeelding 3 van 3
    Koop
    • The next step is to pull out the ribbon cables connected to the motherboard.
    • Each ribbon cable has a sticker covering it; peel it off with tweezers.
    • Use tweezers to pull out the ribbon cable.
    • Make sure to pull the ribbon cable horizontally, not vertically to avoid tearing the ribbon
  8. Acer Iconia A110 On/Off Switch Replacement: stap 8, afbeelding 1 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 8, afbeelding 2 van 3 Acer Iconia A110 On/Off Switch Replacement: stap 8, afbeelding 3 van 3
    • After all ribbon cables are disconnected,move them out of the way, and the motherboard should fall out easily.
  9. Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: stap 9, afbeelding 1 van 3 Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: stap 9, afbeelding 2 van 3 Acer Iconia A110 On/Off Switch Replacement, On/Off Switch: stap 9, afbeelding 3 van 3
    • After the motherboard is removed, the buttons are visible on the side.
    • If you do not have soldering experience, STOP HERE. View this link for an ifixit soldering guide.
    • Use a soldering iron and a soldering wick to desolder the button. This could be tough due to the lead free solder used in the manufacturing process.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Andrea
757 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-42, Maness Spring 2014 Lid van Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 3,082
