Ga door naar hoofdinhoud
Acer Chromebook CB3-532-C47C Speaker Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: stap 2, afbeelding 1 van 2 Acer Chromebook CB3-532-C47C Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: stap 3, afbeelding 1 van 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: stap 4, afbeelding 1 van 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: stap 4, afbeelding 2 van 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: stap 5, afbeelding 1 van 1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook CB3-532-C47C Speaker Replacement: stap 6, afbeelding 2 van 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: stap 7, afbeelding 1 van 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
Conclusie
Sadie Brown
967 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 152
