Ga door naar hoofdinhoud
Acer Chromebook CB3-532-C47C Keyboard Keys Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement, Keyboard Keys: stap 1, afbeelding 1 van 1
    • Place the plastic opening tool directly underneath the key and pry upwards to remove the key.
    • Do not use too much force to avoid separating the retainer clip on the keyboard.
  2. Acer Chromebook CB3-532-C47C Keyboard Keys Replacement: stap 2, afbeelding 1 van 1
    • Repeat with each key that needs to be removed.
    • If you are removing the keys in order to clean the keyboard, please refer to the troubleshooting guide to complete this process.
Conclusie
To reassemble your device, press the keys back onto the keyboard so that the figures are facing you.
Sadie Brown
967 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 278
