Ga door naar hoofdinhoud
Acer Chromebook CB3-111-C670 Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Tony
459 Reputatie
2 handleidingen geschreven
USF Tampa, Team 10-5, Remmell Spring 2016 Lid van USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Leden
8 handleidingen geschreven
Één opmerking
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 4,073
