Inleiding
If your Acer Chromebook 14 CB3-431-C3WS trackpad isn’t registering touch correctly, remaining depressed once you’ve clicked something, or not depressing at all when you click it, you may need to replace your trackpad.
Try looking at this troubleshooting guide to see if there’s a simpler solution before attempting to replace the trackpad.
Make sure that your laptop is completely powered off, and disconnected from all external power sources before beginning your replacement.
Wat je nodig hebt
Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
Remove the strip of tape that secures the motherboard connector to the track pad.
