Ga door naar hoofdinhoud
Acer Chromebook 14 CB3-431-C3WS Speaker Replacement
Wat je nodig hebt
  1. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 3, afbeelding 2 van 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 4, afbeelding 1 van 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: stap 5, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: stap 5, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: stap 5, afbeelding 3 van 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 6, afbeelding 2 van 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Speaker: stap 8, afbeelding 1 van 1
    • Remove the four 4mm JIS #0 screws that hold the speakers in place.
  9. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the clip that connects the speaker wires to the daughterboard.
  10. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: stap 10, afbeelding 1 van 1
    • Lift the speakers from the frame, making sure to carefully unwind the wires connecting the speakers.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 322
