Ga door naar hoofdinhoud
Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement
Wat je nodig hebt
  1. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: stap 5, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: stap 5, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Battery: stap 5, afbeelding 3 van 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Disconnect the LCD cable from the motherboard by removing the tape on the LCD connector, then gently pulling out the ribbon cable.
  9. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 9, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 9, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Disconnect the LCD cable from the motherboard by gently pulling on the cable.
  10. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the trackpad by pulling on the trackpad connector cable.
  11. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 11, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the daughterboard from the motherboard by gently removing the daughterboard cable from the motherboard connector.
  12. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 12, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the electrical tape covering the screw that holds the Wi-Fi card in place.
    • Remove the single 4mm JIS #0 screw that holds the Wi-Fi card in place.
  13. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the seven 4mm JIS #0 screws that hold the motherboard in place.
  14. Acer Chromebook 14 CB3-431-C3WS Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Gently remove the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 1,710
