Ga door naar hoofdinhoud
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 4, afbeelding 1 van 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: stap 5, afbeelding 1 van 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: stap 5, afbeelding 2 van 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: stap 5, afbeelding 3 van 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 6, afbeelding 1 van 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 6, afbeelding 2 van 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: stap 7, afbeelding 1 van 1
    • Lift the battery out gently.
Conclusie
8 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - Antwoord
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 56
Altijd: 5,493
