Ga door naar hoofdinhoud
Acer Aspire R7 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Acer Aspire R7 Wi-Fi Card Replacement, Cover: stap 1, afbeelding 1 van 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 3 Acer Aspire R7 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 3 Acer Aspire R7 Wi-Fi Card Replacement: stap 2, afbeelding 3 van 3
    • Remove seven 10 mm T7 screws.
    • Remove four 6 mm T7 screws.
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining four 10 mm T7 screws.
  3. Acer Aspire R7 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 1 van 2 Acer Aspire R7 Wi-Fi Card Replacement, Wi-Fi Card: stap 4, afbeelding 2 van 2
    • Locate the WiFi Card antenna wires
    • Remove both antenna wires from the WiFi card by prying upwards with the spudger tool
  5. Acer Aspire R7 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the (1) 3.5mm #00 Phillips retaining screw
    • Once the screw is removed, the spring loaded hinge will tilt the WiFi card up
  6. Acer Aspire R7 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • With the retaining screw removed, pull the WiFi card out of the socket
Conclusie
Andrew Rodiek
601 Reputatie
4 handleidingen geschreven
USF Tampa, Team 3-4, Hickman Winter 2015 Lid van USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Leden
7 handleidingen geschreven
2 opmerkingen
The factory wi fi card is so weak. Is there a better wi fi card to buy and put in? 952-454-1659 Thank you
John - Antwoord
This answer might be useful for others who still want to update their Wifi card in their R7-572.
I just replaced the original Broadcom BCM943228HMB on my R7-572 with an Intel 7260HMW CN: 08TF1D (Standard half-height mini PCI-e interface card ). I found it on ebay:https://www.ebay.ca/itm/4-0-Wireless-Min... (19 USD as of October 2018)
After the card is installed, run Intel Driver & Support Assistant and my driver where updated to the latest ones (for both the AC 7260 and the Bluetooth adapter). http://www.intel.com/content/www/us/en/s...
I am using Windows 8.1 on this laptop.
HTH
Michael Cantinotti - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 4,016
