Ga door naar hoofdinhoud
Acer Aspire One 725-0845 Speaker Replacement
Wat je nodig hebt
  1. Acer Aspire One 725-0845 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Speaker Replacement: stap 2, afbeelding 1 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 2, afbeelding 2 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Speaker Replacement, Back Plate: stap 3, afbeelding 1 van 3 Acer Aspire One 725-0845 Speaker Replacement, Back Plate: stap 3, afbeelding 2 van 3 Acer Aspire One 725-0845 Speaker Replacement, Back Plate: stap 3, afbeelding 3 van 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Speaker Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Acer Aspire One 725-0845 Speaker Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: stap 6, afbeelding 1 van 3 Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: stap 6, afbeelding 2 van 3 Acer Aspire One 725-0845 Speaker Replacement, Inner Frame: stap 6, afbeelding 3 van 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Speaker Replacement: stap 7, afbeelding 1 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 7, afbeelding 2 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Speaker Replacement: stap 8, afbeelding 1 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 8, afbeelding 2 van 3 Acer Aspire One 725-0845 Speaker Replacement: stap 8, afbeelding 3 van 3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Speaker Replacement, Speaker: stap 9, afbeelding 1 van 2 Acer Aspire One 725-0845 Speaker Replacement, Speaker: stap 9, afbeelding 2 van 2
    • Lift the black locks for the indicator light connections into the upward position.
    • Remove the indicator light connection by gently pulling the purple tabs away from the locks.
  10. Acer Aspire One 725-0845 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the speakers from the motherboard by carefully pulling the adapter away from the center of the device.
  11. Acer Aspire One 725-0845 Speaker Replacement: stap 11, afbeelding 1 van 1
    • Very carefully remove the speaker wire from the wiring harness.
    • Remove the speakers by lifting them up and away from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Catalfu
281 Reputatie
1 Handleiding geschreven
USF Tampa, Team 8-3, Eyestone Spring 2017 Lid van USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 563
