Ga door naar hoofdinhoud
Acer Aspire 5100 Keyboard Replacement
Wat je nodig hebt
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 Acer Aspire 5100 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: stap 2, afbeelding 1 van 3 Acer Aspire 5100 Keyboard Replacement: stap 2, afbeelding 2 van 3 Acer Aspire 5100 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brad Rollinson
1.113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 14-39, Forte Fall 2010 Lid van Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Leden
10 handleidingen geschreven
1Gids Commentaar
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 13,527
