Inleiding
If the speakers on your ACER Aspire 5 A515-46-R3UB are not working because there is no sound coming out, or the sound is heavily distorted and you want to replace them, follow this guide to easily replace them. Take a look at the ACER Aspire 5 A515-46-R3UB Troubleshooting page to see if there is an alternative fix before beginning the repair.
Be sure to turn off your laptop and disconnect the charger before you begin.
Wat je nodig hebt
Use a JIS #1 screwdriver to remove eleven 6.7 mm screws from the bottom cover.
Één andere persoon heeft deze handleiding voltooid.
