Ga door naar hoofdinhoud
Acer Aspire 3000 RAM Replacement
Wat je nodig hebt
  1. Acer Aspire 3000 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
    Vraag FixBot
    Voeg opmerking toe
  2. Acer Aspire 3000 RAM Replacement: stap 2, afbeelding 1 van 2 Acer Aspire 3000 RAM Replacement: stap 2, afbeelding 2 van 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
    Vraag FixBot
    Voeg opmerking toe
  3. Acer Aspire 3000 RAM Replacement: stap 3, afbeelding 1 van 2 Acer Aspire 3000 RAM Replacement: stap 3, afbeelding 2 van 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Acer Aspire 3000 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
    Vraag FixBot
    Voeg opmerking toe
  5. Acer Aspire 3000 RAM Replacement: stap 5, afbeelding 1 van 1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Acer Aspire 3000 RAM Replacement: stap 6, afbeelding 1 van 1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
    Vraag FixBot
    Voeg opmerking toe
  7. Acer Aspire 3000 RAM Replacement: stap 7, afbeelding 1 van 1
    • Lift and pull the cover back towards you to detach it from the device.
    Vraag FixBot
    Voeg opmerking toe
  8. Acer Aspire 3000 RAM Replacement: stap 8, afbeelding 1 van 1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
    Vraag FixBot
    Voeg opmerking toe
  9. Acer Aspire 3000 RAM Replacement: stap 9, afbeelding 1 van 1
    • Pull and lift the chip to release it from the RAM port.
    Vraag FixBot
    Voeg opmerking toe
  10. Acer Aspire 3000 RAM Replacement: stap 10, afbeelding 1 van 1
    • Repeat step 9 to release the bottom chip from its RAM port.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
roro6730
351 Reputatie
2 handleidingen geschreven
Baylor, Team 4-2, Williams Fall 2016 Lid van Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,106
