Ga door naar hoofdinhoud
Accessing Nokia 3100b Vibrating Unit
Wat je nodig hebt
  1. Accessing Nokia 3100b Vibrating Unit, Battery: stap 1, afbeelding 1 van 1
    • Make sure your phone is turned off.
    Vraag FixBot
    Voeg opmerking toe
  2. Accessing Nokia 3100b Vibrating Unit: stap 2, afbeelding 1 van 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: stap 3, afbeelding 1 van 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Vraag FixBot
    Voeg opmerking toe
  4. Accessing Nokia 3100b Vibrating Unit: stap 4, afbeelding 1 van 1
    • Retrieve your SIM card.
    Vraag FixBot
    Voeg opmerking toe
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: stap 5, afbeelding 1 van 1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
    Vraag FixBot
    Voeg opmerking toe
  6. Accessing Nokia 3100b Vibrating Unit: stap 6, afbeelding 1 van 1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
    Vraag FixBot
    Voeg opmerking toe
  7. Accessing Nokia 3100b Vibrating Unit: stap 7, afbeelding 1 van 1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
    Vraag FixBot
    Voeg opmerking toe
  8. Accessing Nokia 3100b Vibrating Unit: stap 8, afbeelding 1 van 1
    • The vibrating unit can now be accessed. Note its location in the phone.
    Vraag FixBot
    Voeg opmerking toe
  9. Accessing Nokia 3100b Vibrating Unit: stap 9, afbeelding 1 van 1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    Vraag FixBot
    Voeg opmerking toe
  10. Accessing Nokia 3100b Vibrating Unit: stap 10, afbeelding 1 van 1
    • The vibrating unit is now removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sterling Fuentes
139 Reputatie
8 handleidingen geschreven
Cal Poly, Team 29-64, Johann Spring 2010 Lid van Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 1,998
