Ga door naar hoofdinhoud
Accessing LCD Screen
Wat je nodig hebt
    1. Accessing LCD Screen, Front and Back Cover: stap 1, afbeelding 1 van 2 Accessing LCD Screen, Front and Back Cover: stap 1, afbeelding 2 van 2
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
      Vraag FixBot
      Voeg opmerking toe
    2. Accessing LCD Screen: stap 2, afbeelding 1 van 1
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
      Vraag FixBot
      Voeg opmerking toe
    3. Accessing LCD Screen: stap 3, afbeelding 1 van 2 Accessing LCD Screen: stap 3, afbeelding 2 van 2
      • Carefully pull the back of casing away from the front.
      Vraag FixBot
      Voeg opmerking toe
    4. Accessing LCD Screen: stap 4, afbeelding 1 van 3 Accessing LCD Screen: stap 4, afbeelding 2 van 3 Accessing LCD Screen: stap 4, afbeelding 3 van 3
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
      Vraag FixBot
      Voeg opmerking toe
    5. Accessing LCD Screen: stap 5, afbeelding 1 van 2 Accessing LCD Screen: stap 5, afbeelding 2 van 2
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
      Vraag FixBot
      Voeg opmerking toe
    1. Accessing LCD Screen, LCD: stap 6, afbeelding 1 van 2 Accessing LCD Screen, LCD: stap 6, afbeelding 2 van 2
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
      Vraag FixBot
      Voeg opmerking toe
    2. Accessing LCD Screen: stap 7, afbeelding 1 van 2 Accessing LCD Screen: stap 7, afbeelding 2 van 2
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
      Vraag FixBot
      Voeg opmerking toe
    3. Accessing LCD Screen: stap 8, afbeelding 1 van 1
      • Pull the cover plate off for the two power cord jacks.
      Vraag FixBot
      Voeg opmerking toe
    4. Accessing LCD Screen: stap 9, afbeelding 1 van 3 Accessing LCD Screen: stap 9, afbeelding 2 van 3 Accessing LCD Screen: stap 9, afbeelding 3 van 3
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    5. Accessing LCD Screen: stap 10, afbeelding 1 van 1
      • Remove the orange tape on top of the SD cardholder.
      Vraag FixBot
      Voeg opmerking toe
    6. Accessing LCD Screen: stap 11, afbeelding 1 van 3 Accessing LCD Screen: stap 11, afbeelding 2 van 3 Accessing LCD Screen: stap 11, afbeelding 3 van 3
      • Open the battery cover and lift plastic piece off.
      Vraag FixBot
      Voeg opmerking toe
    7. Accessing LCD Screen: stap 12, afbeelding 1 van 1
      • Remove tape on left side of camera.
      Vraag FixBot
      Voeg opmerking toe
    8. Accessing LCD Screen: stap 13, afbeelding 1 van 1
      • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
      Vraag FixBot
      Voeg opmerking toe
    9. Accessing LCD Screen: stap 14, afbeelding 1 van 1
      • Remove top left LCD bracket.
      • This is a small piece, be careful not to lose it.
      Vraag FixBot
      Voeg opmerking toe
    10. Accessing LCD Screen: stap 15, afbeelding 1 van 2 Accessing LCD Screen: stap 15, afbeelding 2 van 2
      • Push down bottom left LCD bracket to release the LCD from grip.
      Vraag FixBot
      Voeg opmerking toe
    11. Accessing LCD Screen: stap 16, afbeelding 1 van 1
      • Gently lift up LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    12. Accessing LCD Screen: stap 17, afbeelding 1 van 3 Accessing LCD Screen: stap 17, afbeelding 2 van 3 Accessing LCD Screen: stap 17, afbeelding 3 van 3
      • Slowly pull LCD screen to the left to remove it from the other grips.
      • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Bassem Tossoun
201 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-29, Regan Winter 2011 Lid van Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,556
