Ga door naar hoofdinhoud
ATT CL2940 Speakerphone Replacement
Wat je nodig hebt
  1. ATT CL2940 Speakerphone Replacement, Back Panel: stap 1, afbeelding 1 van 3 ATT CL2940 Speakerphone Replacement, Back Panel: stap 1, afbeelding 2 van 3 ATT CL2940 Speakerphone Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: stap 2, afbeelding 1 van 3 ATT CL2940 Speakerphone Replacement: stap 2, afbeelding 2 van 3 ATT CL2940 Speakerphone Replacement: stap 2, afbeelding 3 van 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: stap 3, afbeelding 1 van 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: stap 4, afbeelding 1 van 2 ATT CL2940 Speakerphone Replacement, Speakerphone: stap 4, afbeelding 2 van 2
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: stap 5, afbeelding 1 van 3 ATT CL2940 Speakerphone Replacement: stap 5, afbeelding 2 van 3 ATT CL2940 Speakerphone Replacement: stap 5, afbeelding 3 van 3
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: stap 6, afbeelding 1 van 2 ATT CL2940 Speakerphone Replacement: stap 6, afbeelding 2 van 2
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Charles Messmore
541 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-1, Harley Spring 2016 Lid van IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Leden
13 handleidingen geschreven
Één opmerking
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 617
