Ga door naar hoofdinhoud
ASUS ZENFONE 3 Zoom Motherboard Replacement
Wat je nodig hebt
  1. ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom  Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Use the sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 3, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Utilize the PH #00 attachment to remove the 3.3 mm screws in the bracket to the top left of the battery.
  5. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 5, afbeelding 1 van 1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 6, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 7, afbeelding 1 van 1
    • De-solder the single black speaker wire attached to the left side of the phone.
  8. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 8, afbeelding 1 van 2 ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use the flat-edge side of iFixIt plastic spudger to detach both the ribbon connectors off the motherboard at their connection point.
  9. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery, and remove the motherboard.
  10. ASUS ZENFONE 3 Zoom  Motherboard Replacement: stap 10, afbeelding 1 van 1
    • The finished product should be a motherboard with no connections to the body of the phone.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Saif Aiman
243 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G3, Harley Summer 2019 Lid van IUPUI, Team S2-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S2G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 699
