Inleiding
If your Asus laptop screen is cracked it can make it difficult or even impossible to work on the laptop depending on the size of the crack or cracks. The only way to fix this problem is to replace the entire screen.
To do this repair you will need to purchase a new screen and follow the steps in this guide. With no background working with computers you should still be able to complete the repair in under half an hour.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
3 andere personen hebben deze handleiding voltooid.
