Ga door naar hoofdinhoud
ASUS X502CA Battery Replacement
Wat je nodig hebt
    1. ASUS X502CA Battery Replacement, Palm Rest with Keyboard and Touch Pad: stap 1, afbeelding 1 van 1
      • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
      • Use the Phillips #00 screwdriver to remove the four 50mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS X502CA Battery Replacement: stap 2, afbeelding 1 van 1
      • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
      • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
      Vraag FixBot
      Voeg opmerking toe
    3. ASUS X502CA Battery Replacement: stap 3, afbeelding 1 van 2 ASUS X502CA Battery Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
      Vraag FixBot
      Voeg opmerking toe
    4. ASUS X502CA Battery Replacement: stap 4, afbeelding 1 van 2 ASUS X502CA Battery Replacement: stap 4, afbeelding 2 van 2
      • Lift Palm Rest away.
      • Replace with new palm rest.
      Vraag FixBot
      Voeg opmerking toe
    1. ASUS X502CA Battery Replacement, Battery: stap 5, afbeelding 1 van 1
      • Next, locate the battery in the front of laptop (closest to you).
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS X502CA Battery Replacement: stap 6, afbeelding 1 van 1
      • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
      • If battery is not unplugged, motherboard may shock you.
      Vraag FixBot
      Voeg opmerking toe
    3. ASUS X502CA Battery Replacement: stap 7, afbeelding 1 van 2 ASUS X502CA Battery Replacement: stap 7, afbeelding 2 van 2
      • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
      • Once you have removed all six screws carefully lift the battery out and dispose.
      • Each screw is 50 mm in length and 15 mm in diameter.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
David Conner
292 Reputatie
2 handleidingen geschreven
Clemson, Team 14-1, Shirley Winter 2015 Lid van Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Leden
35 handleidingen geschreven
1Gids Commentaar
Thank you for posting this
SteveFFFFF 0 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 15,258
