Inleiding
Use this guide to help you replace a broken or damaged screen in your laptop. Don't forget to keep track of all your screws.
Wat je nodig hebt
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
Remove the four 9 mm Phillips head screws that hold the screen to the base with the PH0 bit.
3 andere personen hebben deze handleiding voltooid.
