Ga door naar hoofdinhoud
ASUS X44H-BBR4 Keyboard Replacement
Wat je nodig hebt
    1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
      • Open the laptop to show the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS X44H-BBR4 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
      • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
      Vraag FixBot
      Voeg opmerking toe
    3. ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 1 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 2 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 3, afbeelding 3 van 3
      • Don't pull too hard on the keys otherwise they may fall off.
      • Push the latch away from the keyboard using the spudger point.
      • While pushing the latches use a plastic opening tool and pull up on a key near it.
      • Continue along the rest of the keyboard until it is released at all four latches.
      Vraag FixBot
      Voeg opmerking toe
    4. ASUS X44H-BBR4 Keyboard Replacement: stap 4, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement: stap 4, afbeelding 2 van 2
      • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
      • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. ASUS X44H-BBR4 Keyboard Replacement: stap 5, afbeelding 1 van 2 ASUS X44H-BBR4 Keyboard Replacement: stap 5, afbeelding 2 van 2
      • Flip the keyboard over to reveal the back of it and what is underneath.
      Vraag FixBot
      Voeg opmerking toe
    6. ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 1 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 2 van 3 ASUS X44H-BBR4 Keyboard Replacement: stap 6, afbeelding 3 van 3
      • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
      • Gently pull out the ribbon cable from the connector piece.
      Vraag FixBot
      Voeg opmerking toe
    7. ASUS X44H-BBR4 Keyboard Replacement: stap 7, afbeelding 1 van 1
      • Remove the keyboard completely.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kelly Merlo
500 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 1,508
