Ga door naar hoofdinhoud
ASUS VG248 Disassembly
Wat je nodig hebt
  1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: stap 1, afbeelding 1 van 2 ASUS VG248 Disassembly, ASUS VG248 Disassembly: stap 1, afbeelding 2 van 2
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
    Vraag FixBot
    Voeg opmerking toe
  2. ASUS VG248 Disassembly: stap 2, afbeelding 1 van 1
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    Vraag FixBot
    Voeg opmerking toe
  3. ASUS VG248 Disassembly: stap 3, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 3, afbeelding 2 van 2
    • Remove the stand from the display.
    Vraag FixBot
    Voeg opmerking toe
  4. ASUS VG248 Disassembly: stap 4, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 4, afbeelding 2 van 2
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
    Vraag FixBot
    Voeg opmerking toe
  5. ASUS VG248 Disassembly: stap 5, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 5, afbeelding 2 van 2
    • Repeat the procedure around the display, lifting up the center of the next side.
    Vraag FixBot
    Voeg opmerking toe
  6. ASUS VG248 Disassembly: stap 6, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 6, afbeelding 2 van 2
    • Move around to the other long side and lift up on the center of the bezel.
    Vraag FixBot
    Voeg opmerking toe
  7. ASUS VG248 Disassembly: stap 7, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 7, afbeelding 2 van 2
    • Grip the center of the final side and lift the bezel away from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  8. ASUS VG248 Disassembly: stap 8, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 8, afbeelding 2 van 2
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    Vraag FixBot
    Voeg opmerking toe
  9. ASUS VG248 Disassembly: stap 9, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Jimmy
    $7.95
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
    Vraag FixBot
    Voeg opmerking toe
  10. ASUS VG248 Disassembly: stap 10, afbeelding 1 van 3 ASUS VG248 Disassembly: stap 10, afbeelding 2 van 3 ASUS VG248 Disassembly: stap 10, afbeelding 3 van 3
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    Vraag FixBot
    Voeg opmerking toe
  11. ASUS VG248 Disassembly: stap 11, afbeelding 1 van 1
    • Remove the bezel.
    Vraag FixBot
    Voeg opmerking toe
  12. ASUS VG248 Disassembly: stap 12, afbeelding 1 van 2 ASUS VG248 Disassembly: stap 12, afbeelding 2 van 2
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    Vraag FixBot
    Voeg opmerking toe
  13. ASUS VG248 Disassembly: stap 13, afbeelding 1 van 1
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
23 andere personen hebben deze handleiding voltooid.
Sam Goldheart
477.696 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
28.236 handleidingen geschreven
11Gids Commentaar
Do you know of any place that sell the replacement lcd screen?
treymcbrd - Antwoord Deel
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - Antwoord Deel
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - Antwoord Deel
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - Antwoord Deel
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 182
Afgelopen 30 dagen: 797
Altijd: 137,319
