Ga door naar hoofdinhoud
ASUS UX50V-RX05 Optical Drive Replacement
Wat je nodig hebt
  1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: stap 1, afbeelding 1 van 3 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: stap 1, afbeelding 2 van 3 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
  2. ASUS UX50V-RX05 Optical Drive Replacement: stap 2, afbeelding 1 van 2 ASUS UX50V-RX05 Optical Drive Replacement: stap 2, afbeelding 2 van 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
  3. ASUS UX50V-RX05 Optical Drive Replacement: stap 3, afbeelding 1 van 2 ASUS UX50V-RX05 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
  4. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: stap 4, afbeelding 1 van 3 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: stap 4, afbeelding 2 van 3 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: stap 4, afbeelding 3 van 3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
  5. ASUS UX50V-RX05 Optical Drive Replacement: stap 5, afbeelding 1 van 2 ASUS UX50V-RX05 Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
  6. ASUS UX50V-RX05 Optical Drive Replacement: stap 6, afbeelding 1 van 3 ASUS UX50V-RX05 Optical Drive Replacement: stap 6, afbeelding 2 van 3 ASUS UX50V-RX05 Optical Drive Replacement: stap 6, afbeelding 3 van 3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
  7. ASUS UX50V-RX05 Optical Drive Replacement: stap 7, afbeelding 1 van 1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
  8. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: stap 8, afbeelding 1 van 2 ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: stap 8, afbeelding 2 van 2
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
Conclusie
James
663 Reputatie
6 handleidingen geschreven
USF Tampa, Team 20-2, Remmell Spring 2017 Lid van USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 389
