Ga door naar hoofdinhoud
ASUS Q536F Screen Replacement
Wat je nodig hebt
    1. ASUS Q536F Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 ASUS Q536F Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      Vraag FixBot
      Voeg opmerking toe
    1. ASUS Q536F Screen Replacement, Display Assembly: stap 2, afbeelding 1 van 1
      • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS Q536F Screen Replacement: stap 3, afbeelding 1 van 3 ASUS Q536F Screen Replacement: stap 3, afbeelding 2 van 3 ASUS Q536F Screen Replacement: stap 3, afbeelding 3 van 3
      • Using your fingers, unplug the two power cables connecting the display to the motherboard.
      • Remove the display assembly from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. ASUS Q536F Screen Replacement, Screen: stap 4, afbeelding 1 van 3 ASUS Q536F Screen Replacement, Screen: stap 4, afbeelding 2 van 3 ASUS Q536F Screen Replacement, Screen: stap 4, afbeelding 3 van 3
      • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
      • Use an iOpener to help loosen the adhesive on the screen.
      • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
      • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
      Vraag FixBot
      Voeg opmerking toe
    2. ASUS Q536F Screen Replacement: stap 5, afbeelding 1 van 1
      • Carefully remove the screen from the rest of the display.
      • The new screen should come with the sticky adhesive.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Adra Ledward
557 Reputatie
5 handleidingen geschreven
Gateway, Team 88-8, Gonzalez Fall 2023 Lid van Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Leden
54 handleidingen geschreven
1Gids Commentaar
I've never had to do a screen replacement but I know my way around PCs. Laptops not as much, but have done other smaller repairs. Replacing the entire screen has me quite anxious. Whats the difficulty level on that?
Acrillix Official - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 811
